Date/Time: Wed, 25 Nov 2026 21:06:11 +0000
How to build a correlation coefficient chart for Gold & USDJPY
View Count: 728
[2025-06-11 14:53:24]
Samksloy - Posts: 1
I have a copy of Correlation Coefficient chart for Crude Oil and SPX 500, If I want to create the same chart for Gold and USDJPY, how should I do it ?
Do you have any tutorial video for this ?
Thank you
Regards
SL
[2025-06-11 15:26:04]
John - SC Support - Posts: 48659
We do not know how your chart is setup, so we cannot really answer properly. Offhand, we would say to duplicate the chart and change the symbols.
There is also a "Correlation Coefficient" study, and if you are using this, you need to have a chart for one symbol, and use the "Add Additional Symbol" to add the other symbol. Then use the Correlation Coefficient study to get what you want.
