Date/Time: Wed, 25 Nov 2026 21:06:12 +0000
Quote Board
View Count: 475
| [2025-06-11 14:08:17] |
| User731023 - Posts: 167 |
Can I start volume over for just RTH hours? In other words do not want O/N volume included. Want it to start again on RTH open. Thanks |
| [2025-06-11 14:54:52] |
| John - SC Support - Posts: 48659 |
What volume are you referring to? Where are you viewing this volume?
| [2025-06-11 14:57:31] |
The Quote Board.
| [2025-06-11 15:36:50] |
That data comes from the exchange, as such there is no way to change it in the Quote Board. If you want to know the volume just for the RTH, then one option would be to use the "Relative Volume" study, which allows you to specify that you only want to use the Day session and it has a "Cumulative Volume" subgraph. Refer to the following: Relative Volume For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
