Date/Time: Wed, 25 Nov 2026 21:24:04 +0000
[Programming Help] - Custom study does not update color correctly when new bars appear
View Count: 592
| [2025-06-08 12:51:11] |
| User174526 - Posts: 1 |
Hello there, after searching for solutions by myself now I need to try it here and hope you can help. I have built a custom study that should color the candle under the rules, that a close outside the range of the previous candle and outside the range of the previously marked candle occures. There are two issues I couldn't fix yet. 1st) The study is working when the market is not active. But as you can see in the attached video, the study is not working reliably when in replay mode. 2nd) I could not find a solution on how to set the coloring up, in order to just color the body of the candle. Attached you find a video showing how the study currently works, and the cpp and dll file. I would be really greatfull for help. All the best! |
Private File Private File |
