Date/Time: Wed, 25 Nov 2026 21:24:00 +0000
Giant Candlestick Overlay on TPO chart
View Count: 989
| [2025-06-08 12:10:50] |
| wavepaver - Posts: 2 |
I have been using sierra chart for a number of years for TPO chart and orderflow. I haven't done many if any changes to my charts in about 2 years, and occasionally when I open sierra or restart it, there will be random new display of chart analysis. Usually I figure it out in a few days time but this one has me stumped. A few weeks ago, I began having these GIANT Grey candlesticks loaded on my TPO chart... from what I understand is it is not possible to Overlay Candles on a TPO chart but this chart has done it...it is also on my Footprint chart. Attached a photo below. I have scrunched the vertical scale to fit the candles, therefore you can not see the TPO of the day very good because its so small. The scale of the Chart of ES starts at 3700 and shows a high of around 9000. Quite a target I must say ;) Can anyone provide any insight please since occasionally these candles are blocking out a period or 3 during the day. Theres 2 images of the samme chart one expanded vertical scale and one scrunched to show. https://www.sierrachart.com/image.php?Image=1749384495227.png https://www.sierrachart.com/image.php?Image=1749384557483.png |
| [2025-06-09 16:08:51] |
You need to look through the studies on that chart and see which one is creating those bars. The best way to do this would be to duplicate the chart, and then remove the other studies one-by-one until you find the one causing this. Then remove that study from the original chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
