Date/Time: Wed, 25 Nov 2026 21:23:52 +0000
sc.CancelAllWorkingOrdersOnExit
View Count: 548
| [2025-06-06 21:33:05] |
| Pavel - Posts: 6 |
Hello, I was unable to find any details in the documentation about the sc.CancelAllWorkingOrdersOnExit member of the s_sc structure. Could you please clarify what exactly this does? Does it cancel all existing working orders when an order is closed, or only when the study is removed, disabled, or the chart is closed? Thank you very much. Best regards, Pavel |
| [2025-06-06 21:44:22] |
| Sierra_Chart Engineering - Posts: 25483 |
It is documented here: Automated Trading Management: CancelAllWorkingOrdersOnExit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
