Date/Time: Wed, 25 Nov 2026 21:23:50 +0000
setting for number bars calculated values
View Count: 937
| [2025-06-06 14:28:20] |
| User6509932 - Posts: 5 |
I want to display number bars calculated values as candlestick bar showing max, min and closing delta value , nonetheless, I can't find the option of "candlestick" in "graph draw type" in subgraph setting , pls kindly advise
| [2025-06-06 14:32:38] |
You can not directly draw the Numbers Bars Calculated Values as a bar. This study is setup to only draw as a table. The first thing we want to point out that there is the "Ask/Bid Volume Difference Bars" that we believe does exactly what you are wanting. Refer to the following: Ask/Bid Volume Difference Bars If, for some reason, you still want to create this yourself from the Numbers Bars Calculated Values, then you would need to use the "Spreadsheet Formula - Bar" study, which allows you to define which subgraph is used for each part of the bar. Refer to the following: Spreadsheet Formula (Bar) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
