Date/Time: Wed, 25 Nov 2026 21:24:05 +0000
Order Type Request
View Count: 629
| [2025-06-06 13:25:03] |
| User98657 - Posts: 420 |
SC, IMHO, you have gone above and beyond with respect to Order Types. There are a myriad of Order Types to choose from. You'd have to wonder how anyone could find a reason to request another, yet I seem to have found one. I'd like to ask that you consider adding a "Stop Limit Chase", or "Stop Chase" if you prefer (though we know the order will be converted from a Stop to a Limit at the exchange). We have a Limit Chase, and we have a Stop Limit, but not a Stop Limit Chase which would follow the market until it reverses in the intended trade direction. My thinking is that if you've constructed a Limit that can chase, you can use the same functionality to construct a Stop Limit that also chases. I can set up a Custom Trading Keyboard Shortcut to get a Stop orderwith an Offset, which is what I want, but it is static. It does not follow the market. I have to continually Flatten and Cancel, then reinitiate.... I tend to work in fast moving markets. I'm not interested in placing a limit order at a specific price hoping the market will reverse at that specific number. The market may not reverse at all, or may not reverse in a given "window" I've determined to be a Support or Resistance area. By utilizing a Stop Limit Chase along with an offset I can initiate an order while the market is still approaching my level and monitor for the reversal. If the market pushes to far in the opposite direction I can remove the order. If/When the market reaches my level and reverses, the stop order is triggered and filled. As always, I appreciate your consideration. |
| [2025-06-06 13:37:56] |
| Sierra_Chart Engineering - Posts: 25483 |
This already exists. It is a Trailing Stop. We will make sure it is supported with Custom Trading Keyboard Shortcuts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-06-06 13:38:04
