Date/Time: Wed, 25 Nov 2026 21:24:02 +0000
how can I put all the indicators in one region?
View Count: 558
| [2025-06-06 09:54:13] |
| User914996 - Posts: 9 |
HI! How can I put all the indicators in one region? See sсreenshot
Date Time Of Last Edit: 2025-06-06 09:56:10
| [2025-06-06 11:44:45] |
| Sébastien - Posts: 156 |
Hello, In the studies settings, you can select which region you want to show the study. You might want to use the scale settings "Independent" or "User defined" if your studies you want to group together don't use the same vertical scale. see screenshot. |
