Date/Time: Wed, 25 Nov 2026 21:24:03 +0000
Order to buy at the price and stop at the price, settings
View Count: 610
[2025-06-06 06:02:23]
JARUSER1964 - Posts: 10
Hi support,
please provide information. Sorry, I can't set it up. I tried to set it up, but without success. Situation. I need to enter a buy order
at the price of 17800 and a stop at the price of 17795. , the current market price is 17700. , I need the buy order to be filled if the price touches or exceeds 17800 and as soon as this happens, activate the stop loss. I asked the broker about the possibility of using the Market If Touched order, but CME does not support the order, only the client. I asked for an overview of the orders that the OCO server supports against CME, but I did not receive information.
Please help me how to proceed. Thank you.
Best regards,
J Pikulík
[2025-06-06 08:32:29]
User135243 - Posts: 337
This is NOT a Market If Touched order, it is a simple BUY STOP order, create your Bracket-Order (TP and SL) and right-click the Buy-column at 17800
[2025-06-06 09:56:14]
thanks for your help. At the Chart DOM level I clicked on the price 19570 to activate the trade in the LONG direction. In Chart DOM Settings - set Left Click on Buy Column Above Last - "Buy Stop". The line B|STOP 19570 appeared on the chart. The current price was 19560. On the Trade Window - set: Target: Limit 2000T and STOP: STOP /Stop Offset 4T. The price rose to 19570 and the order from the Trade Window was activated and the trade went into profit (green line) on the screen. Another line (stop loss) did not appear on the screen. After some time the trade went into a greater negative than 4T (16T). The option in the Trade Window Use Attached Orders - checked... Where did I make a mistake?
Thank you for your help.
J. Pikulik
[2025-06-06 12:15:26]
it is working. I changed STOP part of my order in Trade Window. From STOP ALL OCO Groups, to STOP OCO Group 1. You can close ticket. Working now. Thank You for your help.
Best Regards,
Jaroslav Pikulík
