Date/Time: Wed, 25 Nov 2026 21:24:02 +0000
Bug when entering multiple limit orders in Chart Dom
View Count: 1538
| [2025-06-06 01:21:07] |
| florianh - Posts: 19 |
There seems to be an issue when entering multiple orders into the dom that is attached to chart. The first order always appears immediately when clicking the chart dom, but when trying to click serveral orders rapidly, only half of them actually appear. There seems to be bottleneck when placing several orders (I use Limit orders) which is super annoying when I quickly want to place 5 limit orders and only 3 or less orders are actually placed in the chart dom.
| [2025-06-06 08:36:26] |
| Sierra_Chart Engineering - Posts: 25483 |
There is definitively no bug that exist like this at all. There is some other explanation in your case. One explanation could be that multiple single clicks from your pointer device are interpreted as a double-click and a double-click event will not generate an order. And you should only be testing in Trade Simulation Mode when evaluating an issue like this : Trade Simulation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-06-06 08:57:02
| [2025-06-06 09:27:07] |
Thank you for your response. I tested the fastest and slowest double-click speed in windows. This seems to be the issue because when setting it to fastest, then a litte more orders get entered in the chart dom, but not all. But still, I find it extremely irritating that not each mouse click corresponds to one order, this is very annoying having double check the quantity of entered orders visually or click "slower", especially during trading quick moves. I'm not a programmer, but if there's a way to disable double clicks on the dom that would be a good update because anybody trying to quickly enter 5 orders on the same price by fire-clicking fast, will run into the same problem. Its actually happening in Chart Dom and Dom.
