Date/Time: Wed, 25 Nov 2026 21:06:07 +0000
Stationary Text: add setting to display underneath the main price graph
View Count: 767
[2025-06-05 21:43:11]
User719512 - Posts: 548
The Stationary Text always displays on top of the main price graph.
Feature Requests:
1) Add setting to display underneath the main price graph
2) Add setting for text alignment so multiline text is left/right/center aligned
| Stationary Text |
| Left |
| Stationary Text |
| Right |
| Stationary Text |
| Center |
Also, it appears that while 72 is the largest size one can select, 127 is the largest size you can manually enter. Entering larger values, seems to parse the first 2 digits or something.
Is there a reason for this constraint (like storing size in a signed byte)?
Any reason not to allow larger values?
Use case is using Stationary Text as a watermark/background using a color slightly visible against the background.
Side note: writing my own study and using sc.Graphics.DrawTextAt() with sizes larger than about 130 or 150 (depends on font) results in corrupted text. The custom study will display under the main price graph, but would require much duplication to achieve the same features/capabilities of the Sierra Stationary Text study.
Sierra v2761, OpenGL
[2025-06-06 13:44:21]
John - SC Support - Posts: 48659
1. Refer to the following setting. It does apply to all drawings however.
Chart Settings: Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu)
2. Noted
We can not say offhand why the font entry is limited as it is.
We have noted these items as Feature Requests. We can not say when we would get to any particular item.
[2025-06-06 14:11:53]
We will be looking over today, the first post in this thread.
[2025-06-16 17:02:38]
This might have been fixed in an earlier build between v2761 and v2765, but both feature requests have been confirmed addressed in v2765.
New settings for "Draw Underneath Main Graph" and "Multiline Horizontal Text Alignment".
Thanks Sierra Chart Engineering!
Date Time Of Last Edit: 2025-06-16 17:10:22
