Date/Time: Wed, 25 Nov 2026 21:23:55 +0000
copy tpo chart levels into small timeframe candle charts ?
View Count: 589
| [2025-06-05 09:20:57] |
| 4tunetrader - Posts: 8 |
hi sierra supporters how can we take the main levels vah, val, tpopoc from a tpo chart into a smaller timeframe candle chart ? |
| [2025-06-05 09:35:11] |
| Sébastien - Posts: 156 |
Hi, You can use this study : TPO Value Area Lines |
| [2025-06-05 10:17:54] |
great, thank you for the fast reply ! is there a way to extend the open tpo levels from previous sessions ?
Date Time Of Last Edit: 2025-06-05 11:38:09
| [2025-06-05 14:27:12] |
It depends on what exactly you want to do in terms of extending the lines. To extend the lines from all days all the way forward, use the "Extend Bar Value Until Future Intersection" study. This will not actually stop the lines with the intersection of a bar, as it is looking for another line of the same type at the same price level. Refer to the following: Extend Bar Value Until Future Intersection If you do want to have the lines stop at the intersection with a bar, then refer to the following way to do this: Color Bar Based on Alert Condition: Creating Extension Lines for Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
