Date/Time: Tue, 17 Nov 2026 18:08:48 +0000
[User Discussion] - Working in China
View Count: 1002
| [2025-06-05 08:46:53] |
| User833839 - Posts: 2 |
Anyone use Sierra Chart for real time trade in China? Any data delay?
| [2025-06-05 09:51:16] |
| Sierra_Chart Engineering - Posts: 25432 |
Do you mean you want to trade on the Chinese exchanges and/or get market data from Chinese exchanges? We need to know the exchanges you need market data for.
| [2025-06-05 11:24:06] |
I would like to trade CME's futures from China, need to know if I can get real time data feed and if any delay on real time data. Thanks
| [2025-06-05 14:35:03] |
| John - SC Support - Posts: 48555 |
We have set this as a "User Discussion" for other members to give you their thoughts. You are currently on a Trial, so you have access to the delayed streaming data for the YM and MES symbols from the CME Group. The data is delayed by 10 minutes and 10 seconds, but otherwise is the same data and comes from the same location. So you should be able to get a good feel for how the data works for you from this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
