Date/Time: Wed, 25 Nov 2026 21:24:05 +0000
Number of Forward Columns
View Count: 1024
| [2025-06-04 21:34:59] |
| GARYtheG - Posts: 37 |
Hello Dear Sierra Chart Support Board, is there a way to increase the numbers of forward columns in a extreme way, without increasing the bar times! Any Information to achieve that, even with a costum study is appreciated! Thank you |
| [2025-06-04 21:38:04] |
The only way to increase the number of forward columns is through the following setting: Chart Settings: Number of Forward Columns (Chart >> Chart Settings >> Display >> Chart Display Items menu) If this does not answer your question, then we need more information on what you are trying to do. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-04 22:07:55] |
Yes, its limited to 2000 forward columns but i would need (8000-10.000)
| [2025-06-04 22:11:45] |
| Using SC Since 2020 - Posts: 150 |
+1 Would be a big help |
| [2025-06-04 22:36:42] |
| User457437 - Posts: 3 |
+2
| [2025-06-05 02:18:00] |
| drod93 - Posts: 6 |
+3
| [2025-06-05 07:33:23] |
| Sierra_Chart Engineering - Posts: 25483 |
It has been a while since we worked on the implementation of the forward columns but one thing to be aware of, is that the higher the number the more inefficient, the chart is going to be. It simply is going to have a direct impact on performance. You increase the number, then the more processing time the chart will take. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-05 07:43:02] |
thank you, would it be still possible to uncap the maximum amount to the user?
| [2025-06-05 09:52:00] |
Yes it is not a problem for us to do that, but users just need to understand there is a higher amount of processing the larger that number of forward columns.
| [2025-06-05 09:57:49] |
thank you, understood! It would be appreciated, to be able to test the limits and tweak a setting on the user endpoint
| [2025-06-05 12:54:32] |
| JDN2K - Posts: 3 |
Bump
| [2025-06-05 13:02:42] |
The maximum number of forward bars will allowed to be increased to 10,000 in the next release.
