Date/Time: Wed, 25 Nov 2026 21:23:58 +0000
Sierra will not connect
View Count: 697
| [2025-06-04 08:11:00] |
| User441728 - Posts: 2 |
I have internet and rithmic is connecting but sierra will not. My acct has a surplus balance and is in good standing with denali. Service, username and password are all entered correctly.
| [2025-06-04 09:06:37] |
| User135243 - Posts: 337 |
Try to use another server. I switched to the European-server and it works now. From time to time, SC has problems to connect to the Chicago-server.
| [2025-06-04 09:21:46] |
Even that has not worked. thank you though.
| [2025-06-04 14:07:24] |
Rithmic had a problem with an ISP that caused this issue. They have told us that it is now resolved.
