Date/Time: Wed, 25 Nov 2026 21:23:52 +0000
Request: Support Per Chart Suffix when using Global > symbol entry from chart ...
View Count: 775
[2025-06-04 05:17:11]
barucho - Posts: 17
Current Situation
Currently, to access both the U.S. Equities Consolidated Tape data and the NASDAQ TotalView Market Depth data in a single chart, I need to use symbols with the "_MBO" suffix, such as "NFLX_MBO". This requires me to manually append to each stock symbol I enter, which can be time-consuming and prone to errors, especially when managing multiple charts.
Additionally, when I want to see accurate pulling or stacking, I need to use a chart with the -NQTV suffix.
Feature Request
I would like to request a per-chart setting that allows the user to specify that any stock symbol entered into that chart should automatically have a particular suffix (like "-NQTV" or "_MBO") appended to it. For example, if I type "NFLX" into the chart, it would be automatically treated as "NFLX_MBO" without me having to manually add the suffix.
I believe this would go a long way in helping Sierra Chart better support trading stocks without requiring the use of a pre-built quote board. This would also help support third-party tools such as Trade-Ideas, which supports linking symbol changes with Sierra Chart.
I appreciate the consideration. And if I missed an existing workaround, I apologize.
Thanks for all your work and for an excellent product!
Date Time Of Last Edit: 2025-06-04 05:22:51
[2025-06-06 20:51:22]
This will be in the next release. It will be in Chart >> Chart Settings >> Chart Data.
[2025-06-06 21:38:56]
barucho - Posts: 17
Thank you!
