Date/Time: Wed, 25 Nov 2026 21:23:51 +0000
Can't Delete Trade Activity Entry
View Count: 951
| [2025-06-03 20:13:19] |
| APMS - Posts: 30 |
Hi, I'm using the Trading Evaluator and I want to delete a Trade Activity Entry. However, the option "Delete Trade Activity Entry" is greyed out so I can't perform the action. Is there a way for me to solve this? Thank you! /A |
| [2025-06-03 20:28:03] |
We are not seeing any issue with this. Keep in mind, you need to be on the "Trade Activity" tab and you need to have at least one line highlighted in order to be able to select "Edit >> Delete Trade Activity Entry". If you have an item selected and you are not able to delete it, then please get us an image of the Trade Activity Log with the particular item selected/highlighted, so we can see what you are trying to remove. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-03 21:33:09] |
| APMS - Posts: 30 |
Turns out I was in the "Trades" tab, and I was actually trying to remove a 'trade'. Thank you for your prompt reply helping me with this issue. |
