Date/Time: Wed, 25 Nov 2026 21:23:51 +0000
Effectiveness of sc.BaseGraphScaleConstRange
View Count: 779
[2025-06-03 13:32:40]
Tony - Posts: 738
Hi Sierra Support:
I set my Scale settings as "User Defined" (attached a screenshot), ACSIL has the access to sc.BaseGraphScaleConstRange, I am able to change the number of "Constant Range" even that option is not selected and the height of candle bars changed instantaneously:
  if (sc.CharacterEventCode==83) // press "S", candle bars appear shorter
    sc.BaseGraphScaleConstRange = sc.BaseGraphScaleConstRange+10;
  if (sc.CharacterEventCode==84) // press "T", candle bars appear taller
    sc.BaseGraphScaleConstRange = sc.BaseGraphScaleConstRange-10
that only worked up to version 2739, but it stopped working that way recently, even though the number under "Constant Range" still can be changed by ACSIL, the Height of candle bars don't change, until I exit Sierra Chart and run it again.
It is less convenient than the way worked before, not sure what I had missed.
Thanks so much!
imageScale.png / V - Attached On 2025-06-03 13:30:57 UTC - Size: 109.2 KB - 324 views
[2025-06-03 15:15:26]
The sc.BaseGraphScaleConstantRange should not have changed the chart when the scale is set to "User Defined". We are not sure why it worked at all for you, and perhaps there was a change that corrected this.
When using a Scale type of "User Defined" you can get/set the values using the following functions (note the top options below each of the links given):
ACSIL Interface Members - Functions: sc.GetChartStudyUserDefinedScaleRangeBottom()
ACSIL Interface Members - Functions: sc.SetChartStudyUserDefinedScaleRangeBottom()
