Date/Time: Wed, 25 Nov 2026 21:23:52 +0000
Feature Request
View Count: 877
| [2025-06-02 22:24:51] |
| John M - Posts: 189 |
Hello SC, Could you add an ACS assignment capability to Studies please? It would be very useful to easily toggle a Study to hidden or visible instead of having to open the Studies page (F6) and do it there. There are some studies I like to look at from time to time but don't need or want them visible all the time. Example: I like to toggle a Volume by Price study from hidden to visible and back to hidden. I also do that with moving averages. Being able to switch that with an ACS number button would be really convenient. Thanks ! jm |
| [2025-06-03 03:13:51] |
| Acro - Posts: 459 |
The free show/hide study from OrderFlowLabs is what I tend to use. If there are two studies to show and hide I just duplicate the study and have two buttons assigned on the control bar. |
| [2025-06-03 06:27:39] |
| Cesium - Posts: 179 |
OrderFlowLabs show/hide study isnt avaliable for download
| [2025-06-04 16:33:45] |
| User719512 - Posts: 548 |
The OrderFlow Labs store is available (as I write this), so you can get the OFL Freemium product if you want from https://orderflowlabs.com/pages/ofl-freemium edit: fixed the link to remove the period at the end of sentence that should not be part of the URL Date Time Of Last Edit: 2025-06-04 18:39:58
| [2025-06-04 16:54:33] |
| User431178 - Posts: 910 |
The OrderFlow Laabs store is available (as I write this), so you can get the OFL Freemium product if you want from https://orderflowlabs.com/pages/ofl-freemium. Link not working. Page not found The page you were looking for could not be found. Continue shopping . |
| [2025-06-05 00:29:44] |
| Acro - Posts: 459 |
If you simply go to orderflowlabs.com or google it for yourself you will find it. I would not have mentioned it if it was not both simple and free to find and use |
