Date/Time: Wed, 25 Nov 2026 21:24:04 +0000
The attached window on the trading DOM
View Count: 624
| [2025-06-02 18:56:33] |
| User357195 - Posts: 204 |
SC: Is there a way to make the "attach trade window to chart" window on the SC trading DOM thinner and more elongated? It would then fit the length of the DOM ladder and thus take up a thinner amount of screen space. SC is the best, in my opinion. Thanks in advance. |
| [2025-06-02 21:25:03] |
Not at this time. It is part of the long-term changes to the windows that we are working on. Most of the Trade Window functionality is now replicated in the Control Bars. You should look into setting up a control bar for these purposes, as this would give you more room. You can even set a particular control bar to be attached to the left or right side of the window. Refer to the following: Control Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
