Date/Time: Tue, 17 Nov 2026 18:09:09 +0000
Is there a way to delay even more data from SC data delayed
View Count: 767
[2025-06-02 16:13:42]
User919987 - Posts: 2
I get the delayed SC data, there are delayed by 10min and 10sec. I would like to know if there is a way to delay even more this data ? I need to set to 15min the delay.
Regards
[2025-06-02 16:32:56]
John - SC Support - Posts: 48555
The delay is set and can not be changed. For The CME Group it is 10 minutes and 10 seconds. For other exchanges it is 15 minutes.
[2025-06-02 17:35:03]
Ok thank you for your response. So there is no trick like changing time zone or else to add delay of 5minutes ?
Regards
[2025-06-02 21:15:43]
There is nothing that can be done to change the delay of the data. This is done through our software at the source of the data.
