Date/Time: Wed, 25 Nov 2026 21:23:56 +0000
Adjust minimum width for Graph Draw Types: Price Volume Bars
View Count: 947
[2025-06-02 06:19:32]
User832812 - Posts: 11
I wanted to ask if adjusting the minimum width for this graph draw type would be possible:
Graph Draw Types: Candle Price Volume Bars
I would like for them to get as thin as High Low Bars.
[2025-06-02 14:23:45]
We are not understanding what you re referencing in terms of the "minimum width".
The Price Volume Bars have a setting in the Graphics Settings for their width as a percentage. Refer to the following:
Graphics Settings: Price Volume Width % (Global Settings >> Graphics Settings - Other >> General Graphics)
[2025-06-02 14:29:20]
The width of price volume bars is a range, and the value of that is defined by the volume of that bar. The setting you mentioned seems to relate with the maximum width of that range - but I now want to make the bars with the least amount of volume even thinner, therefore I mean the minimum width. They should be able to get as thin as High/Low bars.
[2025-06-02 16:13:36]
There is no control for the "Minimum Width" of a "Price Volume Bar". The minimum width is determined internally through our code.
[2025-06-02 17:50:47]
Are you able to integrate this as a feature inside your "code"?
[2025-06-02 21:17:07]
We have set this as a "Feature Request", but we can not say when we would get to any particular item.
