Date/Time: Wed, 25 Nov 2026 07:55:49 +0000
ACSIL: get underlying contract symbol/month for bars on a (continuous) intraday chart.
View Count: 1191
| [2025-06-01 22:55:26] |
| RobJ - Posts: 7 |
Is there way using ACSIL to determine which contract symbol/month (CLK vs CLM) was in effect on a particular bar on a intraday chart (continuous contract with volume based rollover). I'm doing some calculations over a number of days and want to know if the OHLC values used were all from 1 symbol/month or that a rollover happened during that period. Thank you. |
| [2025-06-02 09:10:14] |
| Sierra_Chart Engineering - Posts: 25479 |
No, this is not possible to know.
| [2025-06-02 12:56:14] |
We will see if it is not difficult to add a function to get the symbol, for a specific bar in the chart.
| [2025-06-02 12:59:33] |
| User431178 - Posts: 910 |
We will see if it is not difficult to add a function to get the symbol, for a specific bar in the chart. That would be very useful if you can do it. |
| [2025-06-02 19:18:56] |
| RobJ - Posts: 7 |
That would be great! Thank you
| [2025-06-03 01:46:08] |
This function will be added to the next release.
| [2025-06-26 10:28:15] |
| RobJ - Posts: 7 |
Thank you SC! The function is in the latest version: // 2762 int (SCDLLCALL* GetContinuousContractSymbolForBarIndex)(int BarIndex, SCString& r_Symbol); |
| [2025-09-17 13:11:50] |
| User907968 - Posts: 887 |
Sorry to dredge up this old thread, but I wonder if you would consider adding a similar function to get the back adjustment amount?
