Date/Time: Wed, 25 Nov 2026 21:23:52 +0000
spreadsheet help
View Count: 810
[2025-05-31 22:58:17]
User411320 - Posts: 379
using the moving average exponential twice, using inputs based off spreadsheet formula instead of the default settings. Every time I change the length of one of the averages. The data erases and I have to recalculate all the formulas again. please see attached
imageScreenshot 2025-05-31 183534.png / V - Attached On 2025-05-31 22:58:02 UTC - Size: 24.76 KB - 297 views
imageScreenshot 2025-05-31 183602.png / V - Attached On 2025-05-31 22:58:08 UTC - Size: 4.69 KB - 257 views
[2025-06-02 13:13:23]
anyone?
[2025-06-02 13:57:26]
Sawtooth - Posts: 4362
Two solutions:
1. Use the Chart Recalculation - Periodic study.
2. Use a spreadsheet formula to calc the EMA (instead of the study Based On a spreadsheet subgraph), using this example:
Spreadsheet Example Formulas and Usage: Exponential Moving Average
Date Time Of Last Edit: 2025-06-02 13:58:27
[2025-06-02 14:45:42]
Thank you i will try this
