Date/Time: Wed, 25 Nov 2026 21:24:06 +0000
ib
View Count: 959
| [2025-05-30 18:05:25] |
| User282547 - Posts: 17 |
Hi, I have the Market Profile (TPO) chart set to 24 hours, and I’d like to add the Initial Balance from 15:30 to 16:30 (New York time). What’s the best way to do it? I’m considering the following options: Draw a box that highlights the Initial Balance area directly on the TPO profile. Use two horizontal lines to mark the high and low of the Initial Balance range on the TPO chart. Add a horizontal marker (like a bar or label) showing the high and low to the left of the TPO profile. What would you recommend, or is there a better way to do this in Sierra Chart? Thanks! |
| [2025-05-30 18:06:23] |
The TPO Profile has the ability to display the "Initial Balance" within it. Refer to the following and the five items below it: Time Price Opportunity (TPO) Profile Charts: Initial Balance Range For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-30 18:30:18] |
| User584084 - Posts: 348 |
1) Create a new 30 minute candlestick chart. Add the Initial Balance Study to it. 2) Then add the Study Overlay Study to the TPO chart and reference the Initial Balance Study from the candlestick chart. Date Time Of Last Edit: 2025-05-30 18:31:10
