Date/Time: Wed, 25 Nov 2026 21:35:57 +0000
STOP LOSSES
View Count: 792
| [2025-05-30 13:06:10] |
| User531621 - Posts: 145 |
Hi Folks, having trouble with 2 lots and their stop losses. 1st target - 40 ticks - and the stop loss is set as a "stop". 2nd target is not set with a trailing stop loss at 40 ticks. When the market reaches the 1st target, its stop loss remains open, even when the 2nd trailing stop loss is takin out. i have to flatten the trade to get rid of that 1st stop loss. I have tried all different scenarios, but cant figure out to get that 1st stop loss to close when the target is hit. thank you so much
| [2025-05-30 14:16:27] |
Make sure you have the OCO Group option set properly for the Stops and Targets you have setup. Refer to the following: Attached Orders: OCO Group (Group) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-30 16:53:50] |
Brilliant John, thank you so much for helping me tweak the SL settings!!
