Date/Time: Wed, 25 Nov 2026 21:35:59 +0000
The trade account monitor
View Count: 866
| [2025-05-29 22:52:46] |
| User357195 - Posts: 204 |
SC: How do I change the Trade Account Monitor so that it begins each new day's calculations at 5:00 P.M. CDT? When I am On the Trade Account Monitor window menu, and select Balance >> The Adjust Account Balance is blank. ? Date Time Of Last Edit: 2025-05-29 22:55:51
| [2025-05-29 23:10:21] |
I figured it out with the help of Google's AI. :+) Here's how to do it: 1. Open the Trade Account Monitor window: Ensure the Trade Account Monitor is open and displaying the relevant trade account data. 2. Access Chart Settings: Navigate to the "Chart" tab, then "Chart Settings", and finally "Trading". 3. Locate Order Fills Start Date-Time: Identify the "Order Fills Start Date-Time" setting within the Trading section. 4. Set the Date and Time: Choose the specific date and time you want to use as the starting point for the trade data. You can either select a date from the list or manually enter one in the format YYYY-MM-DD. For the time, manually enter the time in 24-hour format (HH:MM:SS). ================================================================= Where do I send my Resume so I can apply for a support person at Sierra Charts? Date Time Of Last Edit: 2025-05-29 23:12:22
| [2025-05-30 04:06:15] |
| Sierra_Chart Engineering - Posts: 25483 |
We did make a posting, that artificial intelligence does not exist. And the information at post #2, is completely wrong. We cannot believe people pay attention to this stuff. Especially something from Google. It is simply wrong. The data on the Trade >> Trade Account Monitor, comes from the external trading service and is not controllable by the user. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-30 04:06:46
| [2025-05-30 14:13:45] |
SC Engineering: The info in that AI worked. It was exactly what I needed to do. All I needed to do was change the time from 00:00:00 to 16:00:00. All times MDT. Sierra Charts are the best, in my opinion. Date Time Of Last Edit: 2025-05-30 14:19:28
