Date/Time: Wed, 25 Nov 2026 21:24:01 +0000
quote board data out of sync
View Count: 944
[2025-05-29 16:52:44]
ephi144 - Posts: 57
i am using denali feed, checked the subscription to the feed etc. all looks good.
charts update correctly but the quote board quotes are out of sync.
for example it says BAH-NQTV is down by $20 in the board but shown correctly on the charts.
COHR-NQTV is off by couple of dollars
AVAV-NQTC - chart and
how can i correct this?
imagedata out of sync.png / V - Attached On 2025-05-29 16:44:58 UTC - Size: 60.81 KB - 299 views
imagedata_out_of_sync_2.png / V - Attached On 2025-05-29 16:52:34 UTC - Size: 47.26 KB - 312 views
[2025-05-29 17:53:25]
We are not seeing any issue with the quote board you show. In particular, we looked at BLD-NQTV. The previous days settlement price was 292.17. The last you show is 280.97, giving a Daily Change of -11.20 (280.97 - 292.17).
You can view the Settlement Price for the previous day by selecting "Window >> Current Quote Window". Refer to the information for the Daily Change at the following:
Getting Quotes: Field Descriptions
[2025-05-29 18:38:11]
ephi144 - Posts: 57
BLD's previous close was 279.22.
[2025-05-30 13:46:19]
ephi144 - Posts: 57
says high for aapl was 211.04 - may be overnight but not RTH. do i need to change some setting to only use RTH session?
imagedata_out_of_sync_3.png / V - Attached On 2025-05-30 13:45:36 UTC - Size: 4.48 KB - 276 views
[2025-06-02 09:42:03]
We see why there is a problem. This will not be resolved today. This will be resolved tomorrow.
