Date/Time: Wed, 25 Nov 2026 21:36:09 +0000
Historical Chart Not Working for CL
View Count: 754
| [2025-05-29 14:14:30] |
| djaltad1996 - Posts: 1 |
Intraday charts work. But when I try to load the Historical symbol for F.US.CLEN25 it gives me an error: Error: Invalid Symbol. It works for intraday but not historical? i'm really confused. |
| [2025-05-29 22:18:16] |
| Sierra_Chart Engineering - Posts: 25483 |
Follow the instructions here to update Symbol Settings: Global Symbol Settings: Update Global Symbol Settings And disable Use Custom Symbol Settings Values. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-29 22:18:40
