Date/Time: Wed, 25 Nov 2026 21:35:48 +0000
Spreadsheet system for trading columns study
View Count: 771
| [2025-05-29 13:40:43] |
| User474110 - Posts: 12 |
Hello, actually I'm using the Spreadsheet system for trading study and I need to use some columns to define some formulas about the data from column A to G. I've realized that I can use the columns from O to Z to define formulas, but I need more columns than those. How I can do to have more columns? Because from AA columns they are used by other studies. Thank you, Ervin |
| [2025-05-29 13:47:03] |
Refer to the following Inputs for the Spreadsheet Study: Spreadsheet Study Inputs: Number of Formula Columns Spreadsheet Study Inputs: Blank Columns Before First Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
