Date/Time: Wed, 25 Nov 2026 21:36:08 +0000
Adjustable stops
View Count: 1124
| [2025-05-28 12:40:09] |
| User572037 - Posts: 41 |
Hi, What settings do I need to change so I can click and drag my stops & TPs? I can't seem to find the solution. Thanks |
| [2025-05-28 15:47:52] |
There is no option to not allow working orders to be modified. If you are not able to modify a working order, then check these items: - There is an option for "Trade >> Chart Trade Settings >> General >> Use Click, Release, Click Method to Adjust Orders". If this is set to "Yes", then you have to modify the orders by clicking once to select, then move the order and click again to set the position. This is different from dragging. - If you are using a "Trade Management by Study" study setup to modify the Stops or Targets, this will move them to a particular location. - A "Move to Breakeven" option setup will move the Stop to a particular location. - If you are using a particular order type, such as a Trailing order, then this will move the order based on the settings. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-28 15:58:49] |
That's what I thought I've never not been able to do it, until I started using some new charts recently. None of the above seems to help. I am just using attached orders, stop & TP. |
| [2025-05-28 16:37:35] |
After you try to move a Target or Stop, check your Message Log and the Trade Service Log (Trade >> Trade Service Log). See if there is anything in either log that gives a reason for why you were not able to move it.
| [2025-05-29 08:53:47] |
Unfortunetly nothing comes up
| [2025-05-29 22:14:45] |
| Sierra_Chart Engineering - Posts: 25483 |
Follow the instructions here to modify an order: Chart Trading and the Chart DOM: Modifying and Canceling Orders on the Chart Make sure this option is enabled: Trade Menu: Chart Trade Mode On (Trade menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-29 22:15:03
| [2025-05-30 08:31:17] |
This has fixed it, thank you
