Date/Time: Wed, 25 Nov 2026 21:36:03 +0000
Limit Touch Chase - can't place via right click->buy/sell limit
View Count: 923
[2025-05-27 20:10:43]
User634406 - Posts: 48
As the title says, when I set everything within the chart trade window and place a limit order it ends up being limit chase, not Limit Touch Chase. I can place Limit Touch Chase only via trade window, selecting the price manually and pressing the buy/sell button. I've tested Limit Touch Chase fills in replay mode, it works as it should, so that part is ok.
I'm probably missing something in terms of settings, but I'm not sure what. How to set it up so that I can place Limit Touch Chase directly from the chart(by right click->buy/sell limit)?
[2025-05-27 20:55:37]
There are right-mouse options for "Buy Limit Touch Chase" and "Sell Limit Touch Chase". You need to add these to the right-mouse options by selecting "Global Settings >> Customize Chart Trade Menu". You will find the items on the left and move them to the right. Then they will be available on the right-mouse options when the chart has "Trade >> Chart Trade Mode On" enabled.
