Date/Time: Wed, 25 Nov 2026 21:35:48 +0000
Overlay (Non-Sync) study
View Count: 784
[2025-05-27 16:33:53]
Dan the Man - Posts: 111
I use 2 Numbers bars, the 1st one is a 14 Range and the 2nd one id a 5 Range Numbers bars chart.
Using these 2 charts takes up all my screen.
I would like to overlay the last 3 bars from the 5 Range Numbers bars chart to the 14 Range Numbers bars chart. That way I only need to look at one chart.
The only study that I can find is the "Overlay (Non-Sync)" study.
But after applying all the setting the "5 Range Numbers bars" are not being displayed on the 14 Range Numbers bars chart.
I attached 3 screen images.
The first 2, show the setting
The 3rd image is what I would like to see.
Or is there a different study that should be used?
Regards,
image1 Overlay (Non-Sync) 14 Range Numbers Bars chart.png / V - Attached On 2025-05-27 16:32:50 UTC - Size: 417.11 KB - 289 views
image2 Overlay (Non-Sync) setting.png / V - Attached On 2025-05-27 16:32:57 UTC - Size: 99.79 KB - 291 views
image3 Overlay (Non-Sync).png / V - Attached On 2025-05-27 16:33:43 UTC - Size: 178.97 KB - 332 views
[2025-05-27 17:24:08]
We responded to this in another thread you opened on the same topic.
[2025-05-27 17:49:09]
Sorry about sending it twice.
I thought I somehow deleted it.
Kind regards
