Date/Time: Wed, 25 Nov 2026 21:35:59 +0000
Overlay (Non-Sync) study
View Count: 744
| [2025-05-27 14:34:16] |
| Dan the Man - Posts: 111 |
Hi, I'm using a 14 Range Numbers Bars chart and a 5 Range Numbers Bars chart. I would like to overlay the last 3 Numbers Bars from the 5 Range Numbers Bars onto the 14 Range Numbers Bars chart (in other words, lower chart onto the higher chart) The only study I can find it the study called: Overlay (Non-Sync) When the "Overlay (Non-Sync)" study is added to 14 Range Numbers Bars chart and in the setting the 5 Range Numbers Bars chart is selected under "Chart Number to Overlay" Then in the "Graph Draw Type", there is no Footprint to select from. (even if I select candlestick, it is not displayed) I attached to screen images to show the setting. If this study will not work, is there another study that can be used? Regards, |
| [2025-05-27 17:19:34] |
There is no option for overlaying the actual Numbers Bars display from one chart to another.
