Date/Time: Wed, 25 Nov 2026 21:23:57 +0000
ZifZag Tune UP
View Count: 790
| [2025-05-27 13:28:45] |
| User360283 - Posts: 538 |
I have been using the ZigZag study for several months. It works very well alerting the daily highs and lows. But it completely misses directional change INSIDE the previous Day Lo and Day High.I've tried to find a setting that fixes tis to no avail. Will you please help with the settings to achieve this? Or maybe Sierra ca make a new ZigZag that does this? Thanks |
| [2025-05-27 17:13:46] |
You need to adjust the Inputs for the study to get what you want. Refer to the following: Zig Zag For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-01 22:50:46] |
I've Set the Calc Mode to 2 and tracked it all last week. On side day down reversals it 2-3 alerts that get over-run to the upside. It does not do this on the Up inside reversal. Maybe ZigZag needs a Sierra tune up? Thans |
