Date/Time: Wed, 25 Nov 2026 21:35:54 +0000
Display Chart Windows
View Count: 770
[2025-05-26 22:28:02]
cmack1011 - Posts: 201
For some reason, when I flip through the different charts inside one chartbook, I get a new chart window for each new chart rather than the new chart just replacing the old chart in the same chart window (see attached pic). Please advise as to how to return to the ability to toggle from one chart to another without a new chart window being created? Thank you.
CNM
imageScreenshot 2025-05-26 at 5.23.33 PM.png / V - Attached On 2025-05-26 22:27:48 UTC - Size: 505.38 KB - 392 views
[2025-05-27 16:38:48]
We are not understanding what exactly you are doing or what exactly you are wanting to have happen.
Existing charts in your chartbook will show as their individual charts. So if you select the tab for a chart, it will display that chart. Those charts already exist in your chartbook.
If you want to have a single chart and change the symbol of that chart, then you can do this using one of the methods at the following link:
Changing the Symbol of a Chart
