Date/Time: Wed, 18 Nov 2026 09:39:27 +0000
Is there anyway to reference other study input?
View Count: 1028
| [2025-05-26 17:21:23] |
| User112927 - Posts: 40 |
Hello, Is it possible to refer to other study input? Similar to 'Study Subgraph Reference. Thanks |
| [2025-05-27 16:33:38] |
| John - SC Support - Posts: 48568 |
Not from the built-in studies. You can do this from a custom study. Refer to the following: ACSIL Interface Members - Functions: sc.GetChartStudyInputFloat() https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-27 16:51:04] |
| [2025-05-27 23:32:51] |
I forgot to ask you, Where can I find the source code for 'Color Bar Based On Alert Condition' study? I only found 'Color Bar Based On Above/Belo'w in Studies.cpp and 'Color Bar Based On Slope' in Studies2.cpp. If you don't mind. Thank you |
| [2025-05-28 14:10:16] |
The "Color Bar Based on Alert Condition" study source code is not available.
