Date/Time: Wed, 25 Nov 2026 21:35:54 +0000
Ask/Bid Pull Stack Sum Diff
View Count: 1425
| [2025-05-26 14:37:14] |
| Pedro7 - Posts: 40 |
When using the Number bars calculated values 2 A/B Pull stack sum diff : What determines how many levels are used ? Is this only in Global settings -->Chart dom settings --> Max bid/ask dept pulling stacking Does changes in chart settings--> market depth --> maximum market depth Pulling stacking level has an effect on A/B pull stack sum diff ? Is it possible to have for one symbol 10 levels and for another 20 levels to calculate this value ? When you specify for eg 20 levels, is that 20 levels ask and 20 levels bid or 10 ask and 10 bid ? Date Time Of Last Edit: 2025-05-26 14:39:20
| [2025-05-27 16:31:24] |
The Pulling Stacking data, including the information that is shown in the Numbers Bars Calculated Values 2, is controlled by the setting for "Global Settings >> Chart DOM Settings >> Max Bid/Ask Pulling/Stacking Levels". This is a global setting, so it applies to all charts. There is not a way to have it set to one value for one chart and another value for another chart. The number of levels specified is per side. So a value of 10 will give 10 Bid side pulling/stacking levels and 10 Ask side pulling/stacking levels. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
