Date/Time: Wed, 25 Nov 2026 21:36:07 +0000
Study:volume at price threshold v2
View Count: 906
[2025-05-26 10:29:28]
Gdraw1234 - Posts: 5
Hi
regarding to the Study:volume at price threshold v2, which i use it to show stack imbalances. I find the study show signal only after the candle is form. Do i have option to make it show signal immediately?
[2025-05-27 16:06:45]
This should not be the case. You should be getting the signals when the situation occurs during the bar development.
What is your setting for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Intraday Data Storage Time Unit"?
If this is set to something close to the bar period, then this would be a reason for this to be occurring. It does not need to be 1 tick, but if you are using 1 minute bars, you do not want this set to 1 minute (you could do 1 or 10 seconds for instance).
