Date/Time: Wed, 25 Nov 2026 21:36:14 +0000
Missing Volume Data in VBP Study
View Count: 976
| [2025-05-24 22:31:52] |
| User840007 - Posts: 4 |
Hi, storage time unit set to 1 tick, VBP time ranges set correctly, intraday chart selected, tried deleting and downloading new data several times, still my VBP Study displays wrong Volume Data for GC,NG,CL (always to little, sometimes just a little, sometimes 30% to little). In Indicies everything fine. longing for the solution. Thanks in Advance.
| [2025-05-24 23:39:28] |
| Sierra_Chart Engineering - Posts: 25483 |
Provide an image of the chart showing this by following these *exact* instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-25 12:32:49] |
https://www.sierrachart.com/image.php?Image=1748176067492.png VBP chart Values displays 71.2k for the 05.23.2025, NGN25, even though the volume in the daily candle and the volume on CME Website display 104,618. At first I thought might be Blocktrades. But i checked the Data, they do not fill the Volume Gap. |
| [2025-05-27 06:43:05] |
Refer to: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
