Date/Time: Wed, 25 Nov 2026 21:35:55 +0000
can not connect my rithmic paper trading
View Count: 1088
| [2025-05-23 03:34:52] |
| User928437 - Posts: 3 |
Cannot connect my rithmic paper trading server today. after I upgrade to the latest version 2758 revision 53109. I've tested the connection using ninjatrader. It works. So I think it might be a issue with Sierra Chart. Please help me solve it. |
| [2025-05-23 04:03:15] |
| ipauls_ - Posts: 8 |
i have he same problem (without update)
| [2025-05-23 04:07:30] |
solved. It's the issue with rithmic Chicago server . switch to other servers to test. it should work
| [2025-05-23 21:12:21] |
| Sierra_Chart Engineering - Posts: 25483 |
Is connection to the Rithmic Chicago server still an issue?
