Date/Time: Wed, 25 Nov 2026 21:35:58 +0000
Trading Window, shortcut for saved configurations
View Count: 855
| [2025-05-23 01:41:01] |
| sadramistes - Posts: 24 |
Hi, i want to attach a shortcut for each of my saved configurations/ presets i have on my trading window but i wasnt able to find it in the global shortcuts menu. I'd appreciate some help. Thank you |
| [2025-05-23 10:46:09] |
| Tr00pz - Posts: 32 |
Control Bar: Control Bar Trade Window Configuration Buttons After following those steps, you can set the keyboard shortcuts by going to Global Settings > Customize Keyboard Shortcuts > Trade Window Configurations Keyboard Shortcuts. A suggestion for SC staff - it would be helpful if you could just go to Customize Keyboard Shortcuts and highlight a 'Control Bar Button Trade Window Config' then customize from here. You already have this functionality for Custom Trading Keyboard Shortcuts where you can highlight a shortcut and click the Customize Trading Command. |
