Date/Time: Wed, 25 Nov 2026 21:36:05 +0000
System Notification Message -> [Do not show this again] checkbox doesn't work
View Count: 1038
| [2025-05-23 00:23:30] |
| xORDERBOOKx - Posts: 191 |
My balance is current for Sierra Chart to be rebilled in two days. The System Notification Message pops up every time I start Sierra Chart. See attached. This happens not just for re-billing Sierra Chart, but if I have CME data re-billing as well. No matter how many times I check the "Do not show this again" box, it keeps coming back up. Is there a way to disable these messages permanently? Thank you. Date Time Of Last Edit: 2025-05-23 02:28:46
| [2025-05-27 15:56:42] |
| Sierra_Chart Engineering - Posts: 25483 |
There may be a reason why that message keeps displaying. View it in your browser and check to see if there any differences compared to the last instance of it. There may be a date and/or time at the bottom of it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-27 17:44:24] |
It went away yesterday and I'm unable to see it on the Sierra Chart Desktop end. I'll update this in the future if it happens again and if I can find any differences between the two (browser and desktop). Thanks. |
