Date/Time: Wed, 25 Nov 2026 21:35:54 +0000
Charts moves to left when I zoom in
View Count: 896
[2025-05-22 21:08:20]
Tradinggod12 - Posts: 13
I have tried looking through the support board and googling and found nothing related to this that actually worked. I have tried using automatic scaling, constant, and user defined with autoset, everytime it moves to the left when I zoom in. How do I get it to stay aligned to the far right as I zoom in and out of the chart?! I have to be all the way zoomed out to get it to be far right which is annoying as I can barely see the price action.
[2025-05-22 21:28:37]
How are you "zooming in"? Are you changing the bar spacing using Page Up/Page Down or Arrow Up/Arrow Down? Or are you using the "Zoom In" tool?
[2025-05-22 21:31:42]
I am using the up down arrow
[2025-05-22 21:44:03]
There is not an option to force the right-most bar to stay in a single position, although as long as you do not specifically change the position, it will stay where it is located. As such, depending on where that bar is located, the chart will shift left/right as you change the bar spacing. The further away the actual last bar is from the very right hand side of the chart determines how much this will move, as everything is staying relative to that far right hand side.
