Date/Time: Wed, 25 Nov 2026 21:36:07 +0000
Remote Build Issue 2025-05-22 09:43
View Count: 1048
| [2025-05-22 14:51:52] |
| User_sl2024 - Posts: 3 |
-- Starting remote build of Custom Studies Source files: VwapFormatted.cpp. 64-bit -- 09:43:26 Allow time for the server to compile the files and build the DLL. Server: https://build.sierrachart.com JSON parse error: The document is empty. -- End of Build -- 09:43:47 ------------------------------------------------------------------------------------------------------------------------------------------------- 2025-05-22 09:43:26.492 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. 2025-05-22 09:43:26.492 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | New receive buffer size: 0 2025-05-22 09:43:26.492 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 67.214.125.8. 2025-05-22 09:43:47.505 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. * 2025-05-22 09:43:47.505 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | CloseSocket call. 2025-05-22 09:43:47.505 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Closed. |
| [2025-05-22 15:09:14] |
| stingray - Posts: 1 |
Can confirm also experiencing the same issue with same log output.
| [2025-05-22 15:09:19] |
| Dennzisme - Posts: 32 |
Server: https://build.sierrachart.com/ JSON parse error: The document is empty. -- End of Build -- 16:57:51 same here |
| [2025-05-22 15:47:14] |
Remote build is working now. Thanks!
| [2025-05-22 16:30:30] |
We are not sure if all the remote build servers are working right now. But there are multiple of them, and the system will cycle through. So giving a few extra tries to do a build should get the build done.
| [2025-05-22 16:37:38] |
Yes. Noticed below. build.sierrachart.com - working build2.sierrachart.com - not working Thanks! |
