Date/Time: Wed, 25 Nov 2026 21:36:09 +0000
About historical data download
View Count: 846
| [2025-05-22 13:00:41] |
| User809027 - Posts: 1 |
I just set F.US.ENQM25 symbol and in chart settings I set Days to Load for Intraday chart Data Type to 700. However,the message log says "2025-05-22 08:56:22.415 | Unable to determine transition date based on volume from files: F.US.EPZ23.dly, F.US.EPH24.dly " "2025-05-22 08:56:22.415 | The F.US.EPH24.dly symbol may not be the active contract month. ""2025-05-22 08:56:22.418 | F.US.EPM25 [CBV] #10 | Error while getting daily settlement price with date 2023-12-15 from file. D:\Sierra_chart_folder\Data\F.US.EPZ23.dly. Error: No Data for read. End of file. " So how to solve this issue? |
| [2025-05-22 14:40:04] |
Have the chart that you are working on for this active and select "Edit >> Delete All Data And Download". You will get a pop-up that shows the list of contract months for that chart. At the bottom is an option for "Download for Daily Data Files Only". Enable that option (make sure it has a checkmark) and then select OK. The daily data will be redownloaded and this should resolve the issue.
