Date/Time: Fri, 20 Nov 2026 22:01:39 +0000
Price at end of Ray
View Count: 1125
| [2025-05-22 12:58:21] |
| User731023 - Posts: 167 |
How do you get price to show at end of Ray. Even with it marked yes, does not show. See Snapshot. Thanks |
| [2025-05-25 17:56:38] |
Several days not answered. Figured I would try again to get one.
| [2025-05-26 14:13:56] |
| Sierra_Chart Engineering - Posts: 25447 |
We apologize we did not reply. We are working on the implementation of this.
| [2025-08-18 15:33:27] |
Thank you for implementing this. Would be nice to have a choice and not have the EV: marker at the end. Just the price. |
| [2026-08-21 13:42:52] |
There is an option to control this in the Chart Drawing properties for the Ray drawing. It is: Show Abbreviations: Yes/No Make sure you are running a current version of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-21 13:44:20
| [2026-08-21 21:26:16] |
| User719512 - Posts: 544 |
Is "Text Vertical Alignment" backwards? For Text Horizontal Alignment it controls where the TEXT is placed relative to the ray. For Text Vertical Alignment Below, I would expect the TEXT to be Below the line.
| [2026-08-22 01:30:41] |
No it is not backwards. It means the point at which it is placed, is at the bottom of the text.
