Date/Time: Wed, 25 Nov 2026 21:36:05 +0000
Pulling/Stacking Levels Overlapping when Combining Ticks
View Count: 923
| [2025-05-22 12:10:10] |
| User2069 - Posts: 34 |
Hi! Ever since Combining Ticks was added to the P/S Columns there's been a little bug with the 1st levels on each side where they are drawn pretty far down and they overlap with the 2nd level. It seems to fix itself whenever price stalls for a bit but it's pretty noticeable when there is a lot of movement. Not a breaking bug or anything but wanted to bring it up in case it hasn't been reported yet. |
| [2025-05-22 14:22:25] |
Please get us an image of what you are seeing, as we have not seen any issues like this ourselves. Follow the instructions at the following link to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-22 15:38:21] |
Might not be the best example but here is one. It looks like it is drawing the value on the lowest price level of the combined ticks. It's not too broken but a lot of times they look almost completely on top of each other and it is a lot more noticeable when its a positive value and it has a volume bar. It also happens on the ask as well though not as bad or often, it seems to be more broken on the bid side for some reason. |
| [2025-05-22 16:23:51] |
Do you only see this with certain symbols? If so, give us one symbol where you see this occur.
| [2025-05-22 16:36:06] |
No it seems to be happening with all symbols. That screenshot was from MNQ5.CME but i just checked NQ and it's happening there too. ES and MES as well if i set it to more than 1. |
