Date/Time: Wed, 25 Nov 2026 21:35:49 +0000
DOM Price Ladder font change
View Count: 1102
[2025-05-22 00:09:33]
User327465 - Posts: 23
Looking at the DOM, I have pointed out a long entry in the image. How do I increase the height of the green box to match the light gray lines? I need to increase the height of the green rectangle. Is there a setting for this? My orders are working ok, just need a bigger box to click.
Date Time Of Last Edit: 2025-05-22 00:12:12
imageimage.png / V - Attached On 2025-05-22 00:08:55 UTC - Size: 182.15 KB - 330 views
[2025-05-22 13:22:38]
Removed.
Date Time Of Last Edit: 2025-05-22 16:37:24
[2025-05-22 16:19:16]
I have changed the font for the Chart Text (Global) and the DOM quantities/sizes (Global), but the green box (red too) doesn't change height. Is there another setting I can change? I also changed the scale settings, but the green box didn't change the height.
I've searched the web and the support board, but found nothing.
[2025-05-22 16:37:11]
We apologize - we did not give the correct information previously.
There is not a way to change the size of that box.
[2025-05-22 16:47:42]
It seems what I am looking for is the box that highlights the price level being pointed to in the Buy and Sell column
Trade DOM Buy Column Lines (also Order Entry Highlight Box)
[Associated Settings Window] - [Link] - [Top]
The color of the vertical Buy order column lines and the box which highlights the price level being pointed to in the Buy column.
In the case of the box which highlights the price level, this is drawn with a special drawing mode for efficiency reasons, so it may not match exactly this color setting. The Trade DOM Buy Column Background color will affect the highlight box color.
[2025-05-22 16:53:29]
That box on my other SC is the height of the gray row. See image.
This problem makes it difficult to select the entry price on the DOM because the box is so narrow in height.
This seems to be a programming issue, since it won't repeat for different installs? or is it associated with the DPI of the monitor?
Date Time Of Last Edit: 2025-05-22 16:59:57
imageScreenshot 2025-05-22 114932.png / V - Attached On 2025-05-22 16:52:56 UTC - Size: 111 KB - 347 views
[2025-05-22 17:55:39]
We are not certain of exactly how the box is determined. The only thing we can state is that it is setup automatically and there is not a way to change it.
