Date/Time: Tue, 17 Nov 2026 18:09:04 +0000
Performance issues with Denali futures feed
View Count: 843
| [2025-05-21 18:55:17] |
| pa_trader - Posts: 36 |
I'm having serious performance issues with Futures Feed from Denali. This has been happening for the last month or so. I'm loading 3 days of data and things have worked smoothly in the past. I just tried switching to delayed data on IQ Feed and there are no performance issues at all. I use a lot of non-time charts so ideally I'd like to avoid switching to 1-second. I'm currently using ver.2611 Please let me know if there are known issues or if there is a way to improve performance. thx |
| [2025-05-21 19:16:56] |
| John - SC Support - Posts: 48555 |
Although we can not point to anything specific in recent versions, 2611 is relatively old. You need to start by updating to the current release, which is v 2758 by following these instructions: Software Download: Fast Update Then see how things are functioning. If you still have a problem, then we need to know what exactly you are seeing that leads you to believe there is some kind of performance inssue. Also, you should look at the information we posted here: Improving Performance with Wider Price Ranges and Increased Trading Activity For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
